Using the Grid Edge DERMS Workspace
The Grid Edge DERMS workspace is comprised of a banner and a panel for displaying tools (for example, DERMS Strategies or DERMS Events).
Understanding the Workspace Banner
The Workspace banner displays connection information and access to the tools you need to manage outages:Screen capture of banner showing the Oracle logo, the application name (OracleUtilities NMS Flex Operations), the connection status, the Tool Selector, and the user menu.
The banner contains the following information and interaction buttons.
1. Application Name
2. Connection Indicator
3. Tools Selection Menu
4. User Menu
Understanding the Connection Indicator
The Connection Indicator shows the client's connection status and a system time based on that status.
• Connected clients display a link symbol, the word Connected, and the current system (server's) date and time.
Screen capture of connection status zone. The system is connected.
• Disconnected clients display a broken link symbol, the word Disconnected, and the date and time when the disconnect occurred.
Screen capture of connection status zone. The system is disconnected and the background color has changed to red.
Note: You cannot view or edit any information while disconnected.
Understanding the Tool Selector
The Tool Selector (Tool selector button is four boxes and a drop-down downward arrow.) provides a drop‑down list of tools that you may open or switch between. The options available depend on your user type.
Tool
DERMS User Type
Description
DERMS Events
All
Displays DERMS Events list.
DERMS Strategies
Supervisor, Administrator
Displays DERMS Strategies list.
DERMS Configuration
Administrator
Displays the DERMS Configuration tool.
Note: To close a tool, click the Close button (Close button is an X.) on the tool's tab or in the tool's title bar.
Understanding the User Menu
The User menu provides the following options.
• About: Displays version and other application information.
• Settings: Launches a Settings dialog box that allows you to configure the appearance or behavior of certain user interface elements.
• Dark Theme: Switches the user interface to a dark theme, which is suitable for low light conditions. This setting is saved with your User Preferences.
• Alternate Row Coloring: When selected, data table rows will have alternating colors.
• Allow Clicking Table Headings to Sort: When selected, you can click the column heading to sort the table on that column. If it is not selected then you must use the Sort button on the Sort/Quick Filter toolbar that is displayed beneath column headings when they are hovered with the mouse or touched on a touch enabled device. See Understanding Table Sorting and Understanding Table Filtering for more information on sorting and filtering tables.
• Show Shortcut Text on Checkboxes/Radio Buttons: When selected, check boxes and radio buttons will show an associated shortcut key in their label, if one exists. This setting allows you to disable the label shortcut text if you feel you are familiar enough with them. For example, in the illustration below, the Map Hide/Display Landbase option is not showing a shortcut when the check box (from this Settings option) is deselected [1] and showing the shortcut (B) when the check box is selected [2]; any configured shortcuts for check boxes and radio buttons will always be shown in the tooltip if hovered with the mouse [3]. Screen captures of shortcut key label hidden [1], displayed [2], and shown in hover text [3].
• Thicker Scroll Bars: When selected, makes vertical and horizontal scroll bars wider than their default. This setting is saved with your User Preferences.
Note: If you are using a mouse with a scroll wheel, it is generally faster to scroll through the table. See Scrolling Using a Mouse Scroll Wheel.
• Logout: Logs you out of Grid Edge DERMS.
Understanding the Tabbed User Interface
You can toggle between tools by using the tabs at the bottom of the Workspace. Most tools open a tab at the bottom of the workspace. You may switch between tools by clicking the tool's tab.
Understanding Common User Interactions
Using Keyboard Shortcuts
Many buttons and tabs have keyboard shortcuts. Hover over the component to display the shortcut.
Screen capture showing the mouse hand cursor hovering over a Floppy drive Save button and the tooltip showing the command and the keyboard shortcut "Save (Ctrl+S)."
Many single-action dialogs that allow text entries also provide a Ctrl+Enter shortcut to save the text and confirm the dialog.
Setting Font Size
The font size in Flex Operations is tied to the browser magnification. Change the font size by holding down the Ctrl key and rolling the mouse wheel toward or away from you.
Vertical Scrolling
Use the scroll wheel to scroll vertically (up and down) through a list.
Horizontal Scrolling
Press and hold the Shift key while turning the scroll wheel to scroll horizontally (side to side).
Understanding Common Table Features
Understanding Table Components
The following image shows an illustrated screen capture of a table showing call outs for the components.
Illustrated screen capture of a table showing the components and actions.
1. Filter pane button (); see Understanding Table Filtering for details.
2. Disable filtering button (Button that disables the current filter.) temporarily disables (removes) currently applied filters; clicking the button again restores the filters.
3. The applied filter name (for example, Default).
4. Filter breadcrumbs show the number of rows being displayed (based on filter criteria) and the quick filtering selections; see Understanding Quick Filters.
5. Remove Quick Filter button () removes any quick filtering selections; see Understanding Quick Filters for more information.
6. Filter results; see Understanding Table Filtering for details.
7. The table Search button. See Understanding Searching in Tables for details on using the Search feature.
8. The header row check box allows you to select all of the table rows.
9. The column sort arrow icon shows the current sort direction for that column; clicking it will sort the table by that column. See Understanding Table Sorting for details.
10. The column filter button () opens the quick filtering options; see Understanding Quick Filters.
Note: See Understanding Table Sorting for details on using the Sort feature.
Changing Column Order and Display
There are a number of options to reorder (move) and hide columns.
• Select a column heading and drag the column to its desired new position.
• Right click a column header and select Hide Column to hide the column.
• Right click a column header and choose Organize Columns... to open the Columns dialog box that allows you to reorder and hide columns.
• Hide or show columns by deselecting or selecting them, respectively.
• Reorder columns by dragging the column row up or down the list.
• Use the positioning buttons to move the column to the top of the list (first column in table), up one position (left in table), down one position (right in the table), or to the end (last column in the table).
Columns dialog box controls. Leftmost button moves the column to the top of the list, next button moves the column up one row, next button moves the column down one row, and last button moves the column to the last row.
Example
The Events List table showing the Status column [1] selected and displayed, [2] deselected and hidden, and [3] displayed and moved to the left in the table.
Illustration of the Columns dialog box with column names listed next to check boxes that, when selected, display the column in the table. Corresponding examples of how the table is rendered given the scenario. 1) Status check box selected; 2) Status check box deselected; 3) Status check box selected and moved up in the Columns dialog box.
Changing Column Widths
Move the mouse pointer over a column heading vertical separator until it changes shape, then click and drag the column to its desired width. You can also right click on any column header and choose Auto Size Column or Auto Size All Columns to let the system auto-correct column widths.
Restoring List Defaults
Right click any header and choose Restore Default Settings to revert all display changes that you have made to that list.
Using Right-Click Context Menus
In lists like Events and Crews, commonly accessed functions are available from the right‑click context menu. Switching steps can also be progressed through right-click context menus.
Revealing Additional Row Information
In many lists, double-clicking a row will display more information about the row. For example, double‑click an Events row to open its Event Details.
Sorting by a Single Column
Tables may be sorted by a column by clicking the column heading or by clicking a Sort button () that is displayed in a toolbar that drops down when your mouse hovers over the column heading.
Double arrow symbol activated to become a Sort Ascending button.
Note: In addition to the Sort button, a Quick Filter button () is displayed. See Understanding Quick Filters for information.
The Sort double arrow button (Up and down arrows side by side button.) is available when the table is not being sorted by that column; once a column is included in a sort, the button will display the current sort direction and clicking it will reverse the sort. Sorting a column will also update the column heading cell to show the sort direction; the sort direction icon is enabled as a button when you hover over it.
Up arrow symbol in column heading and toolbar shows button with current sort direction that, when clicked, will reverse the sort.
Note: Once you sort on a different column, the previous sort column heading updates to remove the sort direction icon.
Sorting by Multiple Columns By Column Selection
If you press the Shift key while selecting columns, each column will be included in a sort. The sort hierarchy is based on the selection order, which is indicated by a number next to the sort direction in the column heading cell.
Example of table sorting showing three columns with numbers signifying the sort hierarchy.
You can change the sort direction for any of the selected columns by pressing Shift and either clicking the sort direction button in the column header or in the drop down toolbar.
Table column heading involved in multiple column sort showing that the sort direction and hierarchy number becomes a button when you hover over it.
Note: If you do not press Shift, you multiple column selection will be lost.
Sorting by Multiple Columns Using the Advanced Sorting Options
To display the Columns dialog box with sorting options, right click a column heading, select Sort and then Show Advanced Sort Options... from the context menu.
The Columns dialog box displays a list of all columns in the table and will be expanded to show a sort configuration pane. Select the column name and then click the Add to sorting list button (Button with arrow head or greater than symbol indicating to add the column to the sorting list.). Once columns have been added, you may arrange the sort order using the controls below the list or by dragging the column name to the desired spot in the list; see Changing Column Order and Display for information on the Columns dialog box controls. Set the sort type by clicking the button on the left to get the proper sort direction.
Quick Filters allow you to filter based on values in a column. To perform a quick filter, hover your mouse over a column heading and then click the filter button (Filter button showing funnel icon with darker selected background.) in the drop down toolbar. In the filter panel that opens, select an item to filter or enter the criteria in the Search box. Once you have filtered on a column, the filter icon (Filter button showing funnel icon with darker selected background.) will be displayed in the column header and a quick filter breadcrumb will display the filter results and criteria. To remove the quick filter, click the remove quick filter button (Remove quick filter button is a counterclockwise circular arrow.).
Example: filtering on the #Out column for a value of 10.Example of quick filtering where (1) is the column being filtered and (2) is the filter criteria.
Note: Quick filtering is applied to all filtered views, but it is removed when you close the tool or log off.
Creating and Using Global and Personal Filter
Tools with table data may be filtered using filter panes that allow you to access Global (system-wide) filters and create and rearrange your own (Personal) filters. You may also create shortcuts to your favorite filters. Filtering in Flex Operations is very similar to filtering in the Web Workspace (see Filtering Data Tables).
To use an existing filter, click the Filter icon (Show filter panel button.) in the upper left corner of the table title area; the Filter pane will open.
The Filters pane has collapsible sections (folder icons that expand) that list filters that you have set as Favorites, Global filters saved by your organization, and Personal filters that you have created.
The filter pane will close once you click away from it; to keep it visible, click the pin icon (Pushpin icon to pin the pane open.).
Create a New Personal Filter Folder Structure
To create a personal filter folder, right-click the Personal folder icon and select New Folder....
To create a personal filter, do the following:
1. Select the Personal folder that you want to add the filter to, right‑click, and select New Filter....
2. In the New Filter dialog box, enter the criteria for your filter.
• Name: Your new filter's name.
• Operator: The operator for matching data. See Understanding Operators for information.
• Value: Becomes active when you select an operator that requires a value to match.
Note: See Filtering Data Tables for the operator.
3. Click Add to List to add the filter criteria to list below.
4. You can build more criteria and select whether they all should match or if any can match. Click And to have the filter only show data that matches all of the added filter criteria; click the Or to match a criterion.
Editing and Removing Filters
To edit a filter statement, select it from the list, make your changes, and click Replace.
Removing Filters
You can remove any of the added filter statements by selecting it in the list and clicking Remove. To remove all of the statements in the list, click Clear.
Temporarily Disabling a Filter
Filters may be temporarily disabled by clicking the Disable Filter button (Button that disables the current filter.) next to the filter name. The Filter Name will be updated with strikethrough text to indicate that it is not active. For example, if you’ve selected In Progress to be your filter, but then decide to disable it, the filter bar will indicate so. Click the No Filter button again to restore the filter.
Screen capture of a filter name highlighted with strikethrough text and next to an active disable filter button.
You can search for data and the table will only show rows matching the search criteria. Any rows containing data that matches the criteria will dynamically highlight the matching text. The searching sequence is as follows:Screen capture displaying a filtered table showing rows having ’100’ in different columns.
1. Find and highlight text in any list by clicking the Search icon (Icon has stacked bars with a magnifying glass. Clicking the button will open the Search field.) in the column heading. The Search field will be displayed.
Search field expanded to show that you may enter criteria to filter the table.
2. Enter your search criteria. As you type, the table will begin to highlight matches and hide any rows that do not contain the criteria.
3. To clear the text entered in the Search field, click the Clear button (Clear button. Filled circle with x in the middle.).
4. To close the Search field, click the Close button (Close button (x).).
Exporting Table Information
You can export the information displayed in tables in a variety of formats. To display the export options, right click on a table heading and select Export, then choose one of the following options:
Option
Meaning
Copy (Default Action)
Performs the default copy to clipboard action. This is the same as pressing Ctrl+C. See Default Copy Action below for more information.
Cells to Clipboard
Copies the cell data from the focused column and selected rows to the clipboard.
Column to Clipboard
Copies the cell data from the focused column for all rows in the table to the clipboard.
Rows to Clipboard
Copies the full row data for the selected rows to the clipboard.
All Rows to Clipboard
Copies the full row data for all rows in the table to the clipboard.
Rows to Clipboard (With Headings)
Same as "Rows to Clipboard" but the first row in the copied data will contain the column headings.
All Rows to Clipboard (With Headings)
Same as "All Rows to Clipboard" but the first row in the copied data will contain the column headings.
Rows as Comma Separated Values
Exports the selected rows, including column headings, as comma separated values in a CSV file. The CSV file is downloaded and displayed in your browser's download area.
All Rows as Comma Separated Values
Exports all rows in the table, including column headings, as comma separated values in a CSV file. The CSV file is downloaded and displayed in your browser's download area.
Note: CSV files can be opened in a spreadsheet application, such as Microsoft Office Excel.
Default Copy Action
When Copy (Default Action) is activated from the menu or by pressing Ctrl+C, the default copy action for the table is performed, and a panel will be shown at the bottom of the table with further options allowing quick access to the other copy actions. You can also change the default copy action by selecting Make Default before clicking the action you want to become the new default action.
Understanding Other Table Actions
Many tables provide right-click context menus for actions you may perform on the data (for example, viewing an event's information or location in the Map).
In addition, double-clicking a table row may bring up a different tool with related data.
Understanding Printing
Print menu options are available for lists and detail forms . Selecting the Print... option from a window's File menu, opens a print preview dialog box that allows you to print the contents of the page.
Selecting the Print option for a details page (for example, from Event Details or Switching Sheet Details) invokes a Print Options dialog box that allows you to select what to print.
• Print the current tab
• Print selected tabs
You can select the tabs to print from the list of tabs in the dialog box.
Selecting the Print Options dialog box's OK button opens a print preview dialog box displaying the content that will be output.
The print preview dialog allows you to print to a printer or save to PDF.
