Menu Option | Description | Toolbar Icon |
Export Configuration... | Generates SQL statements for the current state of the configuration associated with every tab on the application. Once generated, the SQL statements are displayed in a window with options to save or print the information. | |
Print Preview | Opens the Print Preview dialog box, which allows you to print the User Administration tab, Event Management Rules tab, Event Details Options tab, and Work Agenda Predefined Filter tab information from the current Configuration Assistant window. See Taking Authority for Control Zones for details on using Print Preview. |
Create Client Installer... | Launches the client installer application. See the Oracle Utilities Network Management System Installation Guide for details on creating the installer and installing local copies of the Oracle Utilities Network Management System client applications. This menu item is available on all tabs. |
Smaller Font | Decreases the font size in text and icons. Repeat to further decrease the font size. |
Bigger Font | Increases the font size in text and icons. Repeat to further increase the font size. |
Reset Font | The application will reset the text and icons to use their default font size. |
Save Preferences | Saves the current settings as the user's preference. See Saving and Restoring Workspace Preferences for details. |
Restore Preferences | Restores the environment preferences to the default settings. See Restoring to Default Preferences for information. |
Change Color Scheme... | Opens the Change Color Scheme dialog box, which allows you to select from different user interface coloring schemes. The options are a Light scheme, a Dark scheme, and the default High Definition scheme. Unlike other user preferences, these apply to all environments for the user on the machine. |
Configuration Assistant Help | Opens the Configuration Assistant online help file. |
Email Log Files... | Gathers the environment's log files and attaches them to a new email message using your default email client. The log files can then be sent to your support team or contact for further analysis. |
Set Debug... | Launches the Set Debug dialog box allowing you to set debug on or off within all client environments. As a Configuration Assistant user type, the dialog box also allows you to set debug within the services (JMService, MTService, etc). This is used for debugging and analysis purposes. See Setting Debug for more information. |
About Configuration Assistant | Opens a dialog box that displays information regarding what version of the application is presently running, as well as version and other information about the Oracle Utilities Network Management System Web Gateway that the application is using. |
