Getting Started with Edge DERMS
The Edge DERMS client is a browser-based application that allows you to create and manage DERMS (distributed energy resources management system) strategies and events to reduce load on the system. The Edge DERMS clients run on personal computes and tablets; see the Oracle Utilities Network Management System Quick Install Guide for supported platforms.
Logging In and Logging Out
To Log In
1. Launch the web link provided by your System Administrator.
2. Enter your User ID and Password, then click Validate.
3. Select your DERMS user type from the User Type drop‑down list, then click Login.
To Log Out
On the Workspace Banner, click your User ID and then select Logout.
Note: Closing the browser is the same as logging yourself out.
