Working with the DERMS Configuration Tool
The DERMS Configuration Tool displays common Edge DERMS configuration options. This tool is available to the DERMS Administrator user. The functions are grouped into tabs:
Users
The Users tab displays a list of DERMS users and user types.
Select a row in the Current Users table to populate the Available User Types and Current User Types tables, and then add or remove user types as desired. You can also add and remove users or edit user details to subscribe to DERMS event state change notifications.
Permissions
The Permissions tab displays permissions associated with each user type, and optionally permissions associated with specific users.
Select a user type in the User Types table to add or remove permissions for that user type. Similarly, select a user in the User Name table to add or remove permissions for that user.
Parameters
The Parameters tab displays global DERMS configuration options, with explanations for each. Select a row and edit it or clear it.
Strategy Types
The Strategy Types tab displays configurable strategy type categories. Select a row and edit it or deactivate it. Higher priority event types that can be scheduled with conflicts will force a cancellation of lower priority events.
Programs
The Programs tab displays the list of available programs, as received from Oracle Utilities Digital Asset Cloud Service (DACS). Right-click and Edit a program to modify some display values for the program and to flag certain rules as override-able.
Data Upload
The Data Upload tab allows you to import a temperature reduction file using the displayed XML file format.
Alerts
The Alerts tab allows you to configure the type of alerts and the recipients to be notified when certain notifications are received from the Oracle Utilities Live Energy Connect (LEC) system.
