Batch Operations Overview
Batch Operations provides a user interface to support Oracle Utilities Application Framework (OUAF) integration with Oracle Scheduler. It facilitates customers and implementers to define, manage and schedule stream of batch jobs to run at periodic intervals using a user friendly interface. In addition, users can monitor the progress of the streams, each of the steps and also perform required exception handling.
Note. Batch Operations user interface can only be used if Oracle Scheduler is used for scheduling and managing batches. Use of third party solutions or schedulers is not supported in current release.
Batch Operations is supported by the following system entities:
Batch Job Stream Definition – a Business Object based on the Batch Job Stream Definition maintenance object
Scheduler Program – a Business Object based on the Scheduler Program maintenance object
