Total Risk Lookups
Work priority and criticality custom lookups require special configuration since they can be searched by range and by greater than and less than values.
The following code descriptions for work priority and asset criticality
are delivered as part of the base product:
- Work Priority: 09 Emergency
- Asset Criticality: 01 Asset Failure Low Impact
The system multiplies the location criticality by the activity work priority to derive a usable total risk value.
To this end, you must configure these lookups, WORK_PRIORITY and CRITICALITY, with the following considerations:
- The Field Value or code must be a 2–digit number. This is required even if your codes do not exceed 09. They must be 2 digits for sorting to function properly.
- The description of the value must have the same two digits at the beginning. Since lookup values show up as drop-downs and drop-down values are sorted by description, starting the description with the code will ensure proper sorting.
