Maintaining Asset Replications
This portal is used to display and maintain large quantities of assets or other devices by batch.
Refer to About Assets for more information.
You can access the portal from Menu, select Asset Management, then select Asset Replication. You are brought to a query portal with options for searching for asset replication information. Once an asset replication has been selected, you are brought to the maintenance portal to view and maintain the selected record.
- Asset Replication: This zone provides details about the replicated assets, asset controls, and new asset IDs.
- Completion Event: This zone displays the completion events associated with the replicated assets.
