Navigate To A Page Steps
BPA scripts only. This step type is
only applicable to BPA scripts.
Navigate to a page steps cause a new page (or tab within the existing page) to be displayed in the object display area. Steps of this type are a precursor to doing anything on the page. The following additional field is required for Navigate to a page steps:
Navigation Option defines the transaction, tab, access mode (add or change) and any context fields that are passed to the transaction in change mode. For example, if you want a script to navigate to Person - Characteristics for the current person being displayed in the dashboard, you must set up an appropriate navigation option. Refer to Defining Navigation Options for more information.
Navigating to a page in update mode. Before you can
navigate to a page in change mode, the page data model must contain
the values to use for the navigation option's context fields. If necessary,
you can move values into the page data model using a Move Data step first. For example, before you can navigate
to a page in change mode with an account ID in context, you may need
to move the desired account ID into the ACCT_ID field in the page
data model. The actual field name(s) to use are listed as context
fields on the navigation option.
