Exporting a Migration
The migration export process begins in the source environment by defining a Migration Data Set Export, which specifies a defined Migration Request and provides a file name and description for the export file. After the data set is defined and saved, the Migration Data Set Export Monitor batch job can be submitted generate the export file. The lifecycle of the Migration Data Set Export business object includes algorithms that select the appropriate records according to the migration request, determine dependencies between records to build groupings of related objects and create the export file.
The following topics provide more detail about this process.
