Digital Asset Management Configuration
This section describes general configuration involved in implementing Oracle Utilities Digital Asset Cloud Service and Oracle Utilities Digital Asset Management.
General Options
Refer to the General Options section for information about configuration of general options including Installation Options, color options, and access control.
Cross Product Configuration
The Cross Product Configuration master configuration provides a single point of access for configuration information related to consolidated data maintenance, data mapping, and other master configurations used with Oracle Utilities Digital Asset Cloud Service and Oracle Utilities Digital Asset Management.
To open the master configuration, select Admin, select General, and select Cross Product Configuration. The master configuration opens in the Cross Product Configuration portal.
The External System field references the external system used for communication between functional components within the application such as data synchronization requests (for example, when a controllable asset is created the system also creates a controllable device record).
Customer and Device Value Mapping
The Customer and Device Mapping section lists objects used to map data between customer-related objects and meter-related objects when synchronizing data between the applications and external applications including Oracle Utilities Customer to Meter.
SA Type Mapping references the extendable lookup used to map service agreement (SA) types to metered service types. Click C2M SA Type Mapping Values to view values for this extendable lookup.
The table lists fields that use Lookup Value Mapping to map values between functional components within the application. Click the Description link to view and/or edit mapping values for a specific field. A plus sign indicates that mapping values have not been defined for that field.
Click the icon to configure values for that field.
Device and Asset Value Mapping
The Device and Asset Value Mapping section lists objects used to map data between asset-related objects and meter-related objects (used when creating new controllable assets and devices).
The table lists fields that use Lookup Value Mapping to map values between functional components within the application. Click the Description link to view and/or edit mapping values for a specific field. A plus sign indicates that mapping values have not been defined for that field. Click the icon to configure values for that field.
Digital Asset Integration Master Configuration
The Digital Asset Integration master configuration is used to define configuration options used when integrating Oracle Utilities Digital Asset Cloud Service  or Oracle Utilities Digital Asset Management with Oracle Utilities Network Management System and/or Oracle Utilities Analytic Insights.
To open the master configuration, select Admin, select General, select  Master Configuration, then click either the Broadcast or Add icon for the Digital Asset Integration Master Configuration.
Refer to the Oracle Utilities Digital Assets Cloud Service Integration to Oracle Utilities Distributed Energy Resources Management System and the Oracle Utilities Analytics Insights Integration to Oracle Utilities Digital Asset Cloud Service and Oracle Utilities Grid Edge Distributed Energy Resources Management System documentation for more information about how this master configuration is used with these integrations.
