Supported ESRI ArcGIS Server Versions
This section provides information on ESRI ArcGIS Server and ArcGIS Desktop compatibility with Oracle Work and Asset Management.
ArcGIS Server Version Compatibility
Oracle Utilities Work and Asset Management can potentially send outbound messages to the ArcGIS Server in either SOAP or REST formats. Please refer to the table below for certified message formats at each supported ArcGIS Server version.
ArcGIS Server Version REST (Work Location and Asset) SOAP (Work Location) SOAP (Asset)
10.8.1 Yes Yes (With TimeReference tag) Yes
10.9.1 Yes Yes (With TimeReference tag) Yes
ArcGIS Server 10.9.1 should be used with ArcGIS Desktop 10.8.2 and ArcGIS Server 10.8.1 should be used with ArcGIS Desktop 10.8.1
ArcGIS Desktop Version Compatibility
The following versions of ArcGIS Desktop are supported with Oracle Utilities Work and Asset Management.
  • 10.8.1
  • 10.8.2
