Understanding Asset Types
Asset types define the attributes for assets and components of a certain type including information such as the valid location types and service history types for the assets and whether or not such assets can have attached components. Also, average cost statistics are graphically displayed on the asset type record.
Assets may be associated with a unique asset number and badge number to allow the asset to be tracked throughout its lifecycle. Users can enter unique asset or badge numbers manually or configure the individual asset types to allow the system to create the asset and badge numbers automatically.
Configuration to auto-generate numbers involves defining the number generation for either the Asset number, Badge number, or for both and defining a Prefix as part of the unique numbering:
- Asset Number
Asset Number Generation: Set to Yes.
Asset Number Prefix: For example, M for meter, P for pole, and so on.
Asset Number Calendar Prefix: Use either 4-digit calendar year or 2-digit calendar year (For example, 2023 or 23)
- Asset Number Sequence Length: 12 digits or less
- Badge Number
Badge Number Generation: Set to Yes.
Badge Number Prefix: For example, M for meter, P for pole, and so on.
Badge Number Calendar Prefix: Use either 4-digit calendar year or 2-digit calendar year (For example, 2023 or 23)
- Badge Number Sequence Length: 12 digits or less
Asset types are defined by:
- Component Relationship: A flag that indicates if components can be installed on assets or components of this type.
- Asset Business Object: The business object used for assets or components based on this asset type.
- Valid Location Types: A list of location types where assets or components of this type can be located.
- Valid Attached To Asset Types: A list of valid asset types where components of this type can be attached (applicable to components only).
- Valid Service History Types: A list of valid service history types that can apply for assets or components of this type.
Refer to Defining Asset Types for more information about setting up asset types.
Asset Classes
Assets are defined by classes, each of which is based on a specific business object, and determines the type of asset: an asset or a component.
The table below lists the asset classes and the business object for each.
Asset Class | Business Object |
Asset | W1-AssetType (Operational Device Asset Type) |
Component | W1-ComponentType (Operational Device Component Type) |
