submitbatch.properties
The submitbatch.properties controls the behavior of individual batch job threads within the batch architecture. This configuration file exists in two forms:
• A global submitbatch.properties that defines global defaults for the implementation.
• A set of
• submitbatch.properties files for individual jobs that defines any configuration overrides or specific configuration settings for an individual job.
This section outlines each setting for the configuration file.
Note: It is recommended to use the Configuring Batch Using Bedit configuration utility to maintain this configuration file.
com.ouaf.batch.jvmoptions - JVM Options
Parameter
Description
Custom JVM Options for submitter.
Note: This setting can be overridden using the -z option on the submitjob.sh - Submit Batch Threads command line.
Ordinality
Mandatory
Valid Values
Valid JVM Options for the Java version used
Source
Maintained by product templates. Use Configuring Batch Using Bedit to implement a different value.
Applicability
Background Processing
Example:
com.ouaf.batch.jvmoptions=-Xms1024k -Xmx2048k -XX:MaxPermSize=512m
com.splwg.grid.executionMode - Mode of Execution
Parameter
Description
Execution Mode used by process.
Note: This setting can be overridden using the -e option on the submitjob.sh - Submit Batch Threads command line.
Ordinality
Mandatory
Valid Values
[ CLUSTERED | THIN ]
Note: The THIN mode is used by the Oracle Utilities SDK and should not be used outside that tool.
Source
Maintained by product templates. Use Implementing Custom Templates to implement a different value.
Applicability
Example:
com.splwg.grid.executionMode=CLUSTERED
com.splwg.batch.submitter - THIN Submitter
Parameter
Description
Whether this execution can run without a threadpoolworker. Reserved for development of batch using the Oracle Utilities SDK. If set to true then, com.splwg.grid.executionMode - Online Execution Mode must be set to THIN.
Ordinality
Mandatory
Valid Values
[false|true]
Source
Maintained by product templates for LOCAL submission.
Applicability
Example:
com.splwg.batch.submitter=true
com.splwg.batch.submitter.batchCd - Batch Code
Parameter
Description
Batch Code for bbatch specific configuration. This setting should not be set in the global submitbatch.properties file.
Note: This setting should only be set in configuration files for testing purposes. In other situations the -b option on the submitjob.sh - Submit Batch Threads command line should be used.
Ordinality
Mandatory
Valid Values
Batch Code
Source
Maintained by product templates for submission.
Applicability
Example:
com.splwg.batch.submitter.batchCd=QABATCH
com.splwg.batch.submitter.distThreadPool - Threadpool
Parameter
Description
Name of pool to be used for batch process. If threadpoolworker not used then LOCAL must be specified.
This can be set globally and at the individual batch job level.
Note: This setting can be overridden using the -p option on the submitjob.sh - Submit Batch Threads command line.
Ordinality
Mandatory
Valid Values
Default: DEFAULT
Source
Applicability
Example:
com.splwg.batch.submitter.distThreadPool=DEFAULT
com.splwg.batch.submitter.languageCd - Language Code
Parameter
Description
Language code used for messages for execution of background process. Relevant language pack must be installed.
Note: This setting can be overridden using the -l option on the submitjob.sh - Submit Batch Threads command line.
Ordinality
Mandatory
Valid Values
Default: ENG
Source
Applicability
Example:
com.splwg.batch.submitter.languageCd=ENG
com.splwg.batch.submitter.maximumCommitRecords - Commit Interval
Parameter
Description
Commit Interval used for execution. This is the number of objects processed per work unit.
Note: This setting can be overridden using the -f option on the submitjob.sh - Submit Batch Threads command line.
Ordinality
Mandatory
Valid Values
Job specific
Source
Applicability
Example:
com.splwg.batch.submitter.maximumCommitRecords=200
com.splwg.batch.submitter.promptForValues - Prompt for Values
Parameter
Description
Prompt for value when running in interactive mode. This is primarily used for developers who are testing their job manually.
Note: Implementers should only use the true value if executing jobs from the Oracle Utilities SDK.
Ordinality
Mandatory
Valid Values
[true|false]
Source
Applicability
Example:
com.splwg.batch.submitter.promptForValues=false
com.splwg.batch.submitter.processDate - Business Date
Parameter
Description
Business Date for batch process. This setting should not be set in the global submitbatch.properties file.
Note: This setting should only be set in configuration files for testing purposes. In other situations the -d option on the submitjob.sh - Submit Batch Threads command line should be used.
Ordinality
Mandatory
Valid Values
Business Date in ISO YYYY-MM-DD format
Source
Applicability
Example:
com.splwg.batch.submitter.processDate=2015-03-08
com.splwg.batch.submitter.rerunNumber - Re Run Number
Parameter
Description
Rerun Number to be used for execution.
Note: Only batch controls that support rerun numbers are supported with this configuration setting.
Note: This setting can be overridden using the -r option on the submitjob.sh - Submit Batch Threads command line.
Ordinality
Optional
Valid Values
Valid run number. A value of zero (0) denotes disables this setting.
Source
Applicability
Example:
com.splwg.batch.submitter.rerunNumber=56
com.splwg.batch.submitter.softParameter - Job Parameters
Parameter
Description
For any program-specific parameters, use this form of property specification in the format:
com.splwg.batch.submitter.softParameter.<parmname>=<value>
The <parmname> denotes the name of the parameter. For example, to specify a number of rows to skip in <value> when submitting a validation program:
com.splwg.batch.submitter.softParameter.SKIP-ROWS=1000
Multiple soft parameters may be specified.
Note: This setting can be overridden using the -x or -X options on the submitjob.sh - Submit Batch Threads command line.
Ordinality
Mandatory
Valid Values
Valid value for parameter
Source
Applicability
Example:
com.splwg.batch.submitter.threadCount - Thread Limit
Parameter
Description
Thread limit used for execution.
Note: Only batch controls that support multithreaded are supported with this configuration setting.
Note: This setting can be overridden using the -c option on the submitjob.sh - Submit Batch Threads command line.
Ordinality
Mandatory
Valid Values
Valid thread limit. A value of one (1) is used for single threaded jobs.
Default: 1
Source
Applicability
Example:
com.splwg.batch.submitter.threadCount=1
com.splwg.batch.submitter.threadNumber - Thread Number
Parameter
Description
Individual thread number used for execution.
Note: This setting can be overridden using the -t option on the submitjob.sh - Submit Batch Threads command line.
Ordinality
Mandatory
Valid Values
Valid thread number. The value must be less than or equal to the com.splwg.batch.submitter.threadCount - Thread Limit. A value of zero (0) spawns multiple threads up to the limit expressed in com.splwg.batch.submitter.threadCount - Thread Limit. Default: 0
Source
Applicability
Example:
com.splwg.batch.submitter.threadNumber=0
com.splwg.batch.submitter.traceProgramEnd - Trace Program End
Parameter
Description
Enables or disables tracing for the end of the program.
Note: This setting is designed for developers and for support purposes.
Note: This setting can be overridden using the -g option on the submitjob.sh - Submit Batch Threads command line.
Ordinality
Mandatory
Valid Values
[true|false]
Source
Applicability
Example:
com.splwg.batch.submitter.traceProgramEnd=false
com.splwg.batch.submitter.traceProgramStart - Trace Program Start
Parameter
Description
Enables or disables tracing for the start of the program.
Ordinality
Mandatory
Valid Values
[true|false]
Source
Applicability
Example:
com.splwg.batch.submitter.traceProgramStart=false
com.splwg.batch.submitter.traceSQL - Trace SQL Statements
Parameter
Description
Enables or disables tracing of ALL SQL statements executed by the program.
Ordinality
Mandatory
Valid Values
[true|false]
Source
Applicability
Example:
com.splwg.batch.submitter.traceSQL=false
com.splwg.batch.submitter.traceStandardOut - Trace Output Statements
Parameter
Description
Enables or disables tracing of ALL in-program debug statements executed by the program.
Ordinality
Mandatory
Valid Values
[true|false]
Source
Applicability
Example:
com.splwg.batch.submitter.traceStandardOut=false
com.splwg.batch.submitter.userId - Security User
Parameter
Description
Userid used by job to check authorization to underlying application services.
Note: This setting can be overridden using the -u option on the submitjob.sh - Submit Batch Threads command line.
Ordinality
Mandatory
Valid Values
Valid userid.
Note: The SYSUSER account should not be used for non-demonstration environments.
Source
Applicability
Example:
com.splwg.batch.submitter.userId=USER01
spl.runtime.batch.L2CacheMode - L2 Cache Control
Parameter
Description
Defines the 2nd-level cache mode. Valid values are READ_ONLY (default), READ_WRITE or OFF.
READ_ONLY is for performance as it loads the configuration entities into the 2nd-level (JVM-level) cache and accesses them from there only. In READ_ONLY mode, the cached entities may not be updated.
READ_WRITE also loads them into the L2 cache, but they can be updated. The drawback is that an update of a cached entity hits both the database and cache as it gets updated in both places.
In OFF mode the 2nd-level cache is completely disabled. Some jobs, for example LDAP import (F1-LDAP), need to update some of these entities (e.g. User), so it requires the L2 cache to be either OFF or READ_WRITE. The choice between OFF and READ_WRITE depends on requirement; the effect is the same.
Note: This setting can be overridden using the -l2 option on the submitjob.sh - Submit Batch Threads command line.
Ordinality
Mandatory
Valid Values
[READ_ONLY|READ_WRITE|OFF]
Source
Applicability
Example:
spl.runtime.batch.L2CacheMode=READ_ONLY
tangosol.coherence.distributed.localstorage - Cache Mode
Parameter
Description
Sets whether data is cached local or not. This is used to optimize large networks of submitters and threadpools with cache nodes.
Ordinality
Mandatory
Valid Values
[true|false]
Source
Applicability
Example:
tangosol.coherence.distributed.localstorage=false
tangosol.coherence.role - Submitter Role
Parameter
Description
Sets role of Submitter. Informational information on JVM used for monitoring purposes only.
Ordinality
Optional
Valid Values
Generated with the name OUAF_<batchcode>_Submitter where <batchcode> is the Batch Control identifier for the batch job.
Source
Applicability
Example:
tangosol.coherence.role=OUAF_QABATCH_Submitter
