Application Viewer
The Application Viewer allows you to explore meta-data driven relationships and other deliverable files online.
Note:Running Stand-Alone. You can also launch the Application Viewer as a stand-alone application (i.e., you do not need to start it from within the system). Refer to Application Viewer Stand-Alone Operation for more information about running the Application Viewer as a stand-alone application.
To open the application viewer from within your application, navigate to Admin > Implementation Tools > Application Viewer. The application viewer may also be launched from other locations for example when viewing a section of the online help files that contain hypertext for a table name, clicking on that hypertext brings you to the definition of that table in the data dictionary.
