Service XML Viewer
The service XML viewer is an interactive tool that allows you to browse the XML files of service programs that execute on the application server.
You can access the service XML viewer as follows:
• The maintenance object viewer allows you to view the XML file of the maintenance object's service program. This feature is implemented by viewing the maintenance object and then clicking on the Service XML icon.
• When viewing a maintenance object on the Maintenance Object page, clicking the View XML hyperlink causes the service’s XML document to be displayed in the Service XML Viewer.
• When viewing a business service on the Business Service page, clicking the View XML hyperlink causes the service’s XML document to be displayed in the Service XML Viewer.
• When setting up a Function, you may want to view the XML document used to pass data to and from the service. Clicking the View XML hyperlink causes the XML document to be displayed in the Service XML Viewer.
