Defining Communication Types
The Communication Type portal is used to display and maintain communication types.
You can access the portal from Admin, select C, then select Communication Type.
  • Communication Type List: This zone lists all communication type records. Broadcast a record to display the details of the selected record.
  • Communication Type: This zone provides information about the selected communication type, such as attachment suppression, communication data mapping, message validation and exception handling.
