Defining Distribution Codes
The Distribution Code portal is used to display and maintain distribution codes.
You can access the portal from Admin, select D, then select Distribution Code.
  • Distribution Code List: This zone lists all distribution code records. Broadcast a record to display the details of the selected record.
  • Distribution Code: This zone displays information about the selected distribution code.
