Defining Storerooms
The Storeroom portal is used to display and maintain storerooms.
You can access the portal from Admin, select S, then select Storeroom. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
  • Storeroom: This zone provides information about the storeroom, such as address information, accounting information, reorder information, and so on.
  • Current Activities: This zone provides summary information about activities that are currently associated with this location.
  • Asset Summary: This zone displays statistical information about the assets associated with this location.
  • Attachments: This zone enables users to manage all types of attachments for the storeroom record.
