Asset Synchronization Batch Processes
Inbound synchronization can be performed for an initial synchronization or for delta updates and changes.
Synchronization request records are processed by the synch request monitor batch process, and it is at that time that the actual outbound message is prepared and sent to the external system.
No batch needs to run explicitly for outbound synchronization as the interface dynamically updates the GIS system.
The following sections describe the background processes involved in asset synchronization from the GIS system.
Initial Synchronization
Step | Batch Code | Description | Additional Parameters (if any) |
1 | W1–GISID | Retrieve GIS ID’s | |
2 | W1–PRGIS | Process GIS Data | |
3 | W1-CMSYN | Composite Sync Request | State: PENDING BO: W1-CompositeSyncReqGISAsset |
4 | F1-SYSRQ | Sync Request Monitor (Deferred) | State: PENDING BO: W1-InitialSyncRequestLocation |
5 | F1-SAKRQ | Sync Request Allocate Keys Monitor | State: DATA-TRANSFD BO: W1-InitialSyncRequestLocation |
6 | W1-SIKSP | Initial Sync Request - Resolve Keys Loc | State: KEY-ALLOCATD BO: W1-InitialSyncRequestLocation |
7 | W1-SILSP | Initial Sync Request - Load Data Location | State: KEYS-RESOLVD BO: W1-InitialSyncRequestLocation |
8 | W1-SILDD | Initial Sync Request - Loaded | State: LOADED BO: W1-InitialSyncRequestLocation |
9 | F1-SYSRQ | Sync Request Monitor (Deferred) | State: PENDING BO: W1-InitialSyncRequestAsset |
10 | F1-SAKRQ | Sync Request Allocate Keys Monitor | State: DATA-TRANSFD BO: W1-InitialSyncRequestAsset |
11 | W1-SIKAS |
Initial Sync Request - Resolve Keys Asset |
State: KEY-ALLOCATD BO: W1-InitialSyncRequestAsset |
12 | W1-SILAS | Initial Sync Request - Load Data Asset | State: KEYS-RESOLVD BO: W1-InitialSyncRequestAsset |
13 | W1-SILDD | Initial Sync Request - Loaded | State: LOADED BO: W1-InitialSyncRequestAsset |
14 | W1-DELVR | GIS Delete Version |
Ongoing Synchronization
After the initial conversion is complete, the following batch processes need to be run periodically and in the specified sequence to uptake ongoing delta changes to eligible assets from the GIS system.
4 | W1-SIOPE | Ongoing Sync Request - Pending | State: PENDING BO: W1-OngoingSyncRequestLocation |
5 | W1-SIOPE | Ongoing Sync Request - Pending | State: PENDING BO: W1-OngoingSyncRequestAsset |
6 | W1-DELVR | GIS Delete Version |
