Jump to main content
Oracle Utilities Work and Asset Management and Operational Device Management
  1. Home
  2. Oracle Utilities Operational Device Management User Guides
  3. Administrative User Guide
  4. Work and Asset Management Administrative User Guide
    The topics in this section describe how to administer Oracle Utilities Work and Asset Management.
  5. Integrations
  6. ESRI ArcGIS Server
  7. Installing the ArcGIS Web Adapter
  • Oracle Utilities Operational Device Management User Guides
    • Business User Guide
    • Administrative User Guide
      • Framework Administrative User Guide
      • Work and Asset Management Administrative User Guide
        • General Options
        • Configuration Options
        • Table Setup Sequence
        • Documents
        • Organizations
        • Compliance
        • Service History
        • Assets
        • Operational Device Management
        • Inventory
        • Purchasing
        • Work Options
        • Preventive Maintenance
        • Scheduling
        • Approvals
        • Financials
        • Integrations
          • Understanding Integrations
          • Understanding Web Services
          • Understanding GIS Integration
          • ESRI ArcGIS Server
            • Supported ESRI ArcGIS Server Versions
            • Installing and Configuring ESRI ArcGIS Desktop
            • Installing and Configuring ESRI ArcGIS Server
            • Configuring the Enterprise Geodatabase
            • Importing Data to Geodatabase
            • Publishing Data as Services in the ArcGIS Server
            • Creating Web Maps Using ArcGIS Online
            • Installing the ArcGIS Web Adapter
            • Installing and Configuring the ArcGIS Portal
            • Creating Web Maps Using ArcGIS Portal
            • Configuring Inbound Sync (GIS)
            • Changes to ENVIRON.INI
          • Configuring GIS Integration
          • Understanding Data Synchronization
          • Configuring Inbound Communication Options
          • Enterprise Resource Planning Integration
          • Creating Application Links in External Applications
        • Defining Oracle Utilities Digital Asset Cloud Service / Digital Asset Management Options
For information about installing and configuring ArcGIS web adapter, refer to:
  • https://enterprise.arcgis.com/en/web-adaptor/latest/install/iis/install-arcgis-web- adaptor-portal.htm
© Oracle   About Oracle   Contact Us   Products A-Z   Terms of Use and Privacy
