Maintaining Program Subscription Contacts
The Contact portal is used to display and maintain program subscription contacts.
Refer to About Program Subscription Contacts for more information.
You can access the portal from Menu, select Digital Asset Management, then select Program Subscription Contact. You are brought to a query portal with options for searching for a specific record. Once a program subscription contact has been selected, you are brought to the maintenance portal to view and maintain the selected record.
The following zones may appear as part of the portal's Main tab page:
  • Contact: This zone displays general information about the contact, such as the contact's name and contact information (phone number, email address, and so on).
