Defining Analytics Attribute Mapping
This portal maps extensions to user defined fields provided for tables associated with an analytics dimension table that capture well defined extension data. A common example of this type of data are characteritics.
These mappings may be directly maintained on the operational Analytics Dimension portal. Refer to Understanding Operational Analytics for more information.
If your system is integrated with the Oracle Utilities Analytics product refer to Understanding Analytics Integration for more information about ETL based characteristic mapping.
You can access the portal from the
You are brought to a query portal with options for searching for a specific mapping record. Once a record has been selected you are brought to the this portal to review the information for the selected record.The Analytics Attribute Mapping zone on the portal's Main tab page provides information about the mapping record.
For characteristic mapping, only Adhoc and
Pre-defined characteristic types are
supported.
For the product provides support for identifier mapping for
operational analytics in this release but only the metadata definition is supported. The support
for these types of attributes in the operational analytics product is in a future release.
