Defining Program Control Score Calculation Groups
You use the Program Control Score Calculation Group portal to display and maintain program control score calculation groups.
Refer to Understanding Program Control Score Calculation Groups for more information.
You can access the portal by selecting Admin, select Digital Asset Management, then select Program Control Score Calculation Group. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
  • Program Control Score Calculation Group: This zone displays basic information about program control score calculation group.
  • Program Control Score Calculation Rules List: This zone lists the program control score calculation rules belonging to the group.
