Oracle Utilities Analytics Insights Integrations
The Oracle Utilities Analytics Insights Integration to Oracle Utilities Digital Asset Cloud Service and Oracle Utilities Grid Edge Distributed Energy Resources Management System supports integrations between components of the Oracle Utilities DERMS solution, Oracle Utilities Digital Asset Cloud Service and Oracle Utilities Analytics Insights. This integration provides the following functionality:
Customer Enrollment Data Synchronization: Once a customer and their controllable device is successfully enrolled in Oracle Utilities Digital Asset Cloud Service, it triggers a message to synchronize the data with Oracle Utilities Analytics Insights for the associated service point so that it is included in load reduction forecasting and actual "kWh Avoided" and "kW Drop" calculations.
Event Outcome - Settlement Calculations: After completion of a scheduled event Oracle Utilities Grid Edge Distributed Energy Resources Management System sends event outcome details for each device to Oracle Utilities Analytics Insights. This enables the computation of "kWh Avoided" and "kW Drop" values to use in financial settlements and the calculation of the load reduction forecast for the corresponding service point.
Load Reduction Forecast: Oracle Utilities Analytics Insight periodically sends a load reduction forecast file containing the forecasted load reduction values for all metered service points associated to an active program enrollment to Oracle Utilities Grid Edge Distributed Energy Resources Management System. Oracle Utilities Grid Edge Distributed Energy Resources Management System uses the load reduction forecast, device score, and availability to reserve the optimal set of controllable devices for a program event.
- Program Settlement Creation: Oracle Utilities Analytics Insights sends files to Oracle
Utilities Digital Asset Cloud Service which contain the actual consumption or demand
reductions achieved for the duration of the event for each customer. Oracle Utilities
Digital Asset Cloud Service records and uses the kWh avoided information to determine
financial settlement data. There are two types of these files:
"KWH Avoided" files contain consumption reduction values. See Processing KWH Avoided Files for more information.
- "KW Drop" files contain demand reduction values. See Processing KW Drop Files for more information.
Refer to the Oracle Utilities Analytics Insights Integration to Oracle Utilities Digital Asset Cloud Service and Oracle Utilities Grid Edge Distributed Energy Resources Management System documentation for more information about this integration.
