Defining Distribution Codes
The Distribution Code portal is used to display and maintain distribution codes.
Refer to Understanding Financials for more information.
You can access the portal from Admin, select Financial, then select Distribution Code.
- Distribution Code List: This zone lists all distribution code records. Broadcast a record to display the details of the selected record.
- Distribution Code: This zone displays information about the selected distribution code.
