Defining Failure Modes
The Failure Mode portal is used to display and maintain failure modes.
You can access the portal from Admin, select Asset Management, then select Failure Mode.
- Failure Mode List: This zone lists all failure mode records. Broadcast a record to display the details of the selected record.
- Failure Mode: This zone provides information about what has failed, such as arcing, binding, backward, and so on.
- Included on Failure Profile: This zone lists the failure profiles associated with a particular failure mode.
