Defining Planners
The Planner portal is used to display and maintain planner records.
Refer to Understanding Scheduling for more information.
You can access the portal from Admin, select Work Management, then select Planner.
- Planner List: This zone lists all planner records. Broadcast a record to display the details of the selected record.
- Planner: This zone provides information about the selected planner.
