Defining Timekeepers
The Timekeeper portal is used to maintain timekeeper records.
Refer to Understanding Resource Charges for more information.
You can access this portal from Admin Menu, select Resource Management, then select Timekeeper. You are brought to a query portal with options for searching for a specific record. Once the timekeeper record has been selected, you are brought to the maintenance portal where you can view and maintain the selected record.
The following zones may appear as part of the portals Main tab page:
- Timekeeper: This zone provides information about the selected timekeeper, the status of the timekeeper and the list of employees the timekeeper can enter time for.
