Maintaining Physical Inventories
The Physical Inventory portal is used to display and maintain a physical inventory record.
You can access the portal from Menu, select Inventory, then select Physical Inventory. You are brought to a query portal with options for searching for a specific record. Once a record has been selected, you are brought to the maintenance portal to view and maintain the selected record.
  • Physical Inventory Header: This zone displays basic information about the selected physical inventory record as well as zones for Required and Optional criteria, Items Summary, and Other Information.
  • First Count Information: This zone displays the inventory count records that have been generated.
  • Recount Information: This zone displays the list of Physical Inventory Count records along with additional fields for entering the Recount value and a First Count field displaying the First Count value.
  • Completed Count Information: This zone displays the list of completed Physical Inventory Count records.
