Unauthenticated HEA Shared Data Elements
The data elements on this page are shared across the Unauthenticated Home Energy Analysis survey subject areas.
Email Provided
| Data Element | Description |
The email address of the unauthenticated customer (if the customer provided one when taking the survey). Type: Attribute |
Unauthenticated User
| Has Email |
An indicator of whether there is an email address for the customer. Type: Attribute |
| Locale |
The locale of the unauthenticated customer, as described in the Locale attribute in the shared Energy Affordability dimension. Type: Attribute |
| Opt In |
Indicates a user's preference to receive marketing communications from their utility after providing their email address to receive a link back to the results from the anonymous survey. Type: Attribute |
| Primary Pa |
The Primary Program Administrator for the customer. This is generally only applicable for state-wide implementations of the unauthenticated version of the survey. Type: Attribute |
| Referral Code |
Unique code a customer can enter to help track the origin of a referral or marketing campaign that drove the customer to take the unauthenticated survey. Type: Attribute |
| Secondary Pa |
The Secondary Program Administrator for the customer. This is generally only applicable for state-wide implementations of the unauthenticated version of the survey. Type: Attribute |
| State |
The state manually entered by the user as part of the survey flow to validate that they live in the correct service territory and to select their utility. This attribute is only applicable for state-wide implementations of the unauthenticated version of the survey. Type: Attribute |
| Zip Code |
The zip code manually entered by the user as part of the survey flow to validate that they live in the correct service territory. This attribute is only applicable to state-wide or single implementations of the unauthenticated survey. Type: Attribute |
