Web - Authentications
The Web - Authentications subject area contains data elements about customers logging in to their web accounts or viewing an embedded widget. Contact your Delivery Team if you have questions about how logins are defined and tracked.
| Data Element | Description |
| Unique Customer Count |
A count of unique customers who authenticated. Type: Measure |
| Web Authentications Count |
The total number of web authentications or logins across all customers. For example, if one user logs in three times and a separate user logs in five times, this would count as a total of eight authentications. The definition of an authentication varies slightly depending on how the web product is implemented.
Note: If you have both an embedded and a standalone web portal implementation, then the web authentications count is a sum of both types of implementations. The count does not distinguish between authentications for each type. Type: Measure |
