6 Engagement Metrics Extract (Incremental)
The Engagement Metrics extract contains details about customer engagement events (such as clicks and bounces) that occur for Oracle Utilities Opower outbound communications, such as Email Home Energy Reports with an event date within a specified date range. It is available as a standard recurring extract if you Contact Your Delivery Team.
| Column | Description |
| utility_customer_id |
The customer identifier that is used on customer communications. This
is usually the same value as the Example: 1234-1234-1234-1234 Field Size: 40. Can Be Empty?: No. |
| communication_id |
Unique ID for the communication. Can be used to join with the Outbound Communications extract. Field Size: 21. Can Be Empty?: No. |
| event_type |
The engagement event type. Allowed Values:
Field Size: 12. Can Be Empty?: No. |
| event_date |
Date and time of event. Field Size: 19. Can Be Empty?: No. |
| url |
Click Uniform Resource Locator (URL). This field is only populated for click events. Field Size: 255. Can Be Empty?: Yes. |
| reason |
Bounce reason. Only populated for bounce events. Field Size: 255. Can Be Empty?: Yes. |
