7 Full Customer Extract
The Full Customer Extract contains a complete listing of all utility customers in one or more program waves, or the entire utility population for Web For All customers. It is a more detailed version of the Basic Customer Extract and is available as a standard recurring extract if you Contact Your Delivery Team.
Either the Basic or Full Customer Extract is applicable to each utility. Your Delivery Team will work with you to identify which one is applicable to you.| Column | Description |
| utility_customer_id |
The customer identifier that is used on customer communications. This
is usually the same value as the Example: 1234-1234-1234-1234 Field Size: 40. Can Be Empty?: No. |
| recipient_status |
A flag to indicate whether the customer is a recipient or part of a control group. Allowed Values:
Field Size: 9. Can Be Empty?: Yes. |
| elec_acct_inactive_date |
Inactive date if a customer has deactivated an electric account. Field Size: 10. Can Be Empty?: Yes. |
| gas_acct_inactive_date |
Inactive date if a customer has deactivated a gas account. Field Size: 10. Can Be Empty?: Yes. |
| has_web_account |
Indicates whether the customer has logged into the Energy Efficiency web portal. Note: This column may not be applicable to your situation. Contact Your Delivery Team if you have any questions.Allowed Values:
Field Size: 1. Can Be Empty?: No. |
| has_print |
Indicates whether a customer has an active print Home Energy Report subscription. Allowed Values:
| has_email |
Indicates whether a customer has an active email subscription. Allowed Values:
| first_print_report_date |
Generation date for first print Home Energy Report. Field Size: 10. Can Be Empty?: Yes. |
| print_report_count |
Total number of print Home Energy Reports generated. Field Size: 5. Can Be Empty?: Yes. |
| first_email_report_date |
Generation date for first Email Home Energy Report. Field Size: 10. Can Be Empty?: Yes. |
| email_report_count |
Total number of Email Home Energy Reports generated. Field Size: 5. Can Be Empty?: Yes. |
| opt_out_date |
Date the customer opted out of the Home Energy Report program, if applicable. Field Size: 10. Can Be Empty?: Yes. |
| opt_out_reason |
Reason for customer’s opt-out of the Home Energy Report program, if applicable. Allowed Values:
Field Size: 40. Can Be Empty?: Yes. |
| include_in_test_analysis |
A flag used to denote VIPs who receive reports but who arenot included in measurement and analysis.
Note: This column is only used in select programs. Contact Your Delivery Team if you have any questions.Allowed Values:
| wave |
Program wave name. Example: 201305_E Field Size: 40. Can Be Empty?: Yes. |
| groups |
Comma-separated list of additional customer groups (customized per utility if applicable). Field Size: 512. Can Be Empty?: Yes. |
