Premise Data File Name Conventions
All premise data files transferred to Oracle Utilities must follow a standard naming convention. File name components enclosed in angle brackets (<>) must be populated. File name components enclosed in square brackets ([]) are optional and can be included or left out. Any components without brackets must be part of the file name and should not be changed.
opwr_<utility>_<specification version number>_premise_<yyyyMMddHHmmss>.<gz or zip>
This naming convention is made up of the following components:
- Prefix: The opwr prefix, which is the standard abbreviation for Oracle Utilities Opower.
- Utility Identifier: A three- or four-character code that identifies the utility sending the file. Your Delivery Team will work with you to choose the utility code early in the implementation process. The code needs to be a unique identifier for the utility in the Oracle Utilities Opower system. For example, “The Great Energy Company” might have an identifier of gec.
- Specification Version Number: A three-digit version number of the data transfer specification. Each digit must be separated by a hyphen (-) and not a period or an underscore. This must match the latest number shown in the Specification Version Number column in Premise Data Version History.
- Data Type: The filename must contain the word premise to indicate the type of data it contains.
- Date: The date that the file was generated, in the format yyyyMMddHHmmss.
- File Extension: All files should be gzipped and should end with .gz, or be zipped and end with .zip. If you choose to PGP encrypt your files, then the .pgp extension should be used. In the case of PGP encryption, compression is not required since the encryption process includes file compression. Files can be up to one gigabyte compressed, or up to four gigabytes uncompressed.
File Naming Example
Suppose the specification version number of the document is v2-0-0 and your utility is named "The Great Energy Company.” An example of your utility’s file name would be as follows:
opwr_gec_v2-0-0_premise_20210316131415.gz
Suppose your utility is using PGP-encrypted files. An example of your utility’s file name would be as follows:
opwr_gec_v2-0-0_premise_20210316131415.pgp
Additional Notes
The filename must not exceed 183 characters and must not contain a period (.) unless the period comes right before the file extension. The Oracle Utilities Opower file reception system considers the first period in the file name to be the beginning of a file extension. For example, the following file name is invalid and cannot be processed:
opwr.gec.v2.0.0.premise.20210316131415.gz
