Premise Data Version History
The following table lists updates to the premise data specification by version number and date. The latest version number should be used in the file name that you send to Oracle Utilities. See Premise Data File Name Conventions for more information.
| Update | Specification Version Number | Date |
Update
status_code allowed values in Service Point Fields
to be all caps. Update device_status allowed values in
Device Fields to be
all caps.
v2-0-7 | 08/26/2025 |
Remove
service_agreement_id from Service Point Fields
since it is a redundant column. Add 300 as an allowed
value in interval_size in Measure Component
Fields.
v2-0-6 | 08/07/2025 |
Update
service_quantity_identifier column in Measure Component
Fields to include NET_USAGE as an example value.
v2-0-5 | 06/27/2025 |
Remove
register_id reference from Measuring Component
Fields. This column has been replaced by other columns in the
Interval Data Transfer specification, and so it no longer
applies.
v2-0-4 | 07/20/2023 |
Update
service_point_type_code column description in Service Point Fields
to specify VARCHAR(2) instead of VARCHAR(30). Update
interval_size column description in Measuring Component
Fields to specify that the column cannot be empty.
v2-0-3 | 08/01/2022 |
Expand the list
of allowable values for the unit_of_measure field in
Measuring
Components. Update Premise Data File Name Conventions to be clearer about
file name length limit and what file name components are
required.
v2-0-2 | 04/11/2022 |
| Update examples in Premise Data File Name Conventions to use incremented major version number and current year. | v2-0-1 | 12/06/2021 |
| Increment to a major version number to designate Premise Data Transfer as a core data standard for utilities. Clarify that zip files should only contain one file each. | v2-0-0 | 11/23/2021 |
| Update supported version number for DataConnect extracts. | v1-2-0 | 07/28/2021 |
Update A variety of additional updates were made to improve clarity and meaning. Contact your Delivery Team for a more detailed list of changes. |
v1-1-0 | 10/09/2020 |
| Update multiple field descriptions to improve clarity. Update introductory topics to simplify explanations and improve cross-references. Add new information about common data formats. For a more detailed list of changes, contact your Delivery Team. | v1-0-0 | 05/14/2020 |
| Initial draft of premise data file specification. | v0-9-0 | 11/12/2019 |
