Program Participation File
The program participation file lists the customers and their energy efficiency programs. The following table defines the elements that must be provided in the columns of the file. Each row in the table is a column in the data file.
If Oracle Utilities encounters any program that has not already been defined and sent in a Program Participation Definition file, the corresponding rows in the Program Participation file will be rejected. Oracle Utilities recommends that you confirm with your Delivery Team that the latest definition file has been received before sending any customers with newly-defined program-allowed value pairs. Additionally, if an inactive date is assigned for a program-measure pair, Oracle Utilities will reject any new assignments of customers to that program-measure after that inactive date. Existing customers with the program-measure assignment will not be deactivated.
Column Name Format
customer_id
Unique identifier for the customer.
Note: This customer ID should be the same customer ID that is sent in the billed usage files, as described in Customer Fields.
Type: varchar
Can Be Empty?: No.
premise_id
An identifier for a site occupied by an individual customer.
Note: This premise ID should be the same premise ID that is sent in the billed usage data files, as described in Customer Fields.
Type: varchar
Can Be Empty?: No.
program_id
Key identifier for the program. The program_id must be the same as a program_id already listed in the corresponding program participation definition file.
Type: varchar
Can Be Empty?: No.
measure
A standardized identifier for a procedure or action that was implemented.
The measure should be the same as a measure already listed in the corresponding program participation definition file.
Type: varchar
Can Be Empty?: No.
deemed_annual_savings
Energy saved over the course of the year (in kWh, CCFs, or Therms) for the customer.
Type: floating point
Can Be Empty?: Yes.
deemed_ annual_savings_unit
Unit of measure for deemed_annual_savings.
Type: enum - KWH, K, THERM, T, CCF, C
Note: K, T, and C are alternate short form representations of KWH, THERM, and CCF, respectively.
Can Be Empty?: Yes.
deemed_lifetime_savings
Energy saved over the course of the program (in kWh, CCFs, or Therms) for the customer.
Can Be Empty?: Yes.
deemed_lifetime_savings_unit
Unit of measure for deemed_lifetime_savings.
Can Be Empty?: Yes.
measure_life
The number of years over which the benefits of the energy efficiency measure are expected to accrue.
Can Be Empty?: Yes.
start_date
The start date of the customer's enrollment in the program. The start date must fall inside the active and inactive program dates specified in the program participation definition file. Otherwise, it will be marked as invalid.
Type: datetime (YYYYMMDD HHmm)
Can Be Empty?: No.
end_date
The end date of the customer's enrollment in the program. If this field is left empty, then it is assumed that there is no end date for the customer's enrollment. If this field is populated, then the end date must come after the start_date defined above and must fall inside the active and inactive program dates specified in the program participation definition file. Otherwise, it will be marked as invalid.
Can Be Empty?: Yes.
Example Program Participation File
The following table is an example of a Program Participation file.
customer_id premise_id program_id measure deemed_annual_savings deemed_annual_savings_unit deemed_lifetime_savings deemed_lifetime_savings _unit measure_life start_date end_date
4268110141 304892 Home_energy_audit Replaced_filter 20 KWH 40 KWH 1 20130101 1200
8427500652 492783 Home_energy_audit Replaced_light_bulbs 10 KWH 35 KWH 1.2 20130101 1200
3934977649 622774 Recycling Washer_recycled 20130101 1200
1080095742 654078 Recycling Washer_recycled 20130101 1200
7611477224 208315 Recycling Freezer_recycled 20130101 1200
