Supported Rate Components
Oracle Utilities supports a variety of rate components, which can be mixed and matched to create custom “rate plans” for each utility. The sections below describe the supported rate components. A member of the Delivery Team will work with you to determine which rate components are applicable for your utility’s implementation. This process will include defining the unique identifiers used for each individual component for use throughout subsequent file specifications. This refers to the rate_component column used throughout this document.
