Account Data Version History
The following table lists updates to the account data specification by version number and date. The latest version number should be used in the file name that you send to Oracle Utilities. See Account Data File Name Conventions for more information.
| Update | Specification Version Number | Date |
Update
description of business_name in Person Fields to more clearly explain what is
required.
v2-0-9 | 09/05/2025 |
Update
description of first_name and
last_name in Person Fields to
more clearly explain what is required. Update
status_code in Service Agreement
Fields to more clearly separate allowed values from
definitions.
v2-0-8 | 08/26/2025 |
Update the
description of the service_agreement_end_datetime field
Fields to better advise utilities on how to complete the
field. Update the Service Agreement Service Points File to add a new allowed
value to the usage_flag field.
v2-0-7 | 03/17/2025 |
| Update Main Account File, Person Address File, and Service Agreement Service Points File to include a cross-reference to Account Data File Name Conventions. Remove redundant file naming conventions. | v2-0-6 | 10/01/2024 |
Delete
redundant copy of account_id column from Service Agreement
Fields.
v2-0-5 | 04/17/2023 |
Update
locality in Person Address File
from VARCHAR(64) to VARCHAR(90).
v2-0-4 | 01/04/2023 |
Update Person Fields to improve accuracy of phone number and email address examples. Update Service Agreement Fields to add new columns:
Update Person Address
File to clarify that only the latest address for a
v2-0-3 | 08/02/2022 |
Update
bill_cycle_code column in Account Fields to say it is no
longer required but is preferred. Add person_type and
business_name to Person Fields.
Add business_classification_code to Service Agreement
Fields. Update Account Data File Name Conventions to be clearer about
file name length limit and what file name components are
required.
v2-0-2 | 04/11/2022 |
| Update examples in Account Data File Name Conventions to use incremented major version number and current year. | v2-0-1 | 12/06/2021 |
| Increment to a major version number to designate Account Data Transfer as a core data standard for utilities. Clarify that zip files should only contain one file each. | v2-0-0 | 11/23/2021 |
| Update supported version number for DataConnect extracts. | v1-2-0 | 07/28/2021 |
Update
admin_area_x fields in the Person Address File
to match the same fields in the Premise File. Update
effective_datetime in Service Agreement
Rate Fields to say it cannot be empty. Update
usage_percent field in Service Agreement
Service Points File to say it can be empty.
v1-1-0 | 10/09/2020 |
| Update multiple field descriptions to improve clarity. Merge phone and email field descriptions into the Person Fields topic. Update introductory topics to simplify explanations and improve cross-references. Add new information about common data formats. For a more detailed list of changes, contact your Delivery Team. | v1-0-0 | 05/14/2020 |
| Initial draft of account data file specification. | v0-9-0 | 11/12/2019 |
