Legacy Billing Data Version History
The following table lists updates to the billing data specification by version number and date. The latest version number should be used in the file name that you send to Oracle Utilities. See Legacy Billing Data File Name Conventions for more information.
Update Specification Version Number Date
Update Legacy Billing Data File Name Conventions to be clearer about file name length limit and what file name components are required. v1-19-0 04/11/2022
Clarify that zip files should only contain one file each. v1-18-0 11/23/2021
Update Usage Fields section to clarify that the usage_value field supports negative values. Update Account Fields, Service Point Fields, and Usage Fields sections to use two-column table format. v1-17-0 09/14/2021
Update Customer Fields section to clarify the customer_type field and business_name field descriptions. v1-16-0 06/09/2021
Update a few terms to use more inclusive language. v1-15-0 05/12/2021
Update Customer Fields section to clarify the customer_type description and convert table to a simpler two-column format. v1-14-0 10/09/2020
Move information about the file retention policy to a more prominent place. v1-13-0 05/14/2020
Update titles and naming conventions where applicable to rebrand the specification as a legacy version. Clarify file extension requirements and expectations. Clarify that the service_unit field is required in the case of multi-unit premises. v1-12-0 11/12/2019
Update the list of allowable values in the customer_type field in the Customer Fields section. Clarify purpose of the duration field in the Usage Fields section. v1-11-0 06/14/2019
Clarify that commas cannot be used in usage_value field. Fix typo in active_date description. Update supported values for customer_type, meter_type, and meter_unit fields. v1-10-0 04/10/2019
Edit sections and headings to simplify content and clarify instructions. No substantive changes to technical specifications. v1-9-0 12/12/2018
Updated file retention section to reflect regional differences. v1-8-0 05/08/2018
Updated the descriptions for meter_type and meter_units. Added statement about valid end-of-line separators. v1-7-0 03/19/2018
Updated description of file transfer process. Added information about correcting file upload errors and Oracle file retention policy. v1-6-0 03/03/2018
Added new ccb_account_id field in Customer table. Removed duplicate account_id field from Usage table. v1-5-0 01/12/2018
Updated definition of the bldg_sq_foot value to clarify that it does not generally include spaces such as the garage, unfinished basement, or porch. v1-4-0 06/26/2017
Added a statement about the utility's data obligations. Removed information about register_id. v1-3-0 03/31/2017
Added document number and updated branding. v1-2-0 02/10/2017
Added legal notices. Updated document branding. v1-1-0 01/11/2017
Added baseline specification version number to the document. Updated naming conventions to include instructions on how to specify a population token and specification version number in the data file. Added more detail to language_preference description. v1-0-0 09/22/2016
Added note to the is_estimate description to clarify that user-reported reads are treated as estimated reads and to standardize the default value for all locales. Updated the usage_value description to change the upper bound from 999999 to 999,999,999. Not applicable. 05/27/2016
Clarified that data from the utility's production system is required. Fixed minor typos. Not applicable. 05/09/2016
