Program Participation Data Version History
The following table lists updates to the program participation data specification by version number and date. The latest version number should be used in the file name that you send to Oracle Utilities. See Program Participation Data File Name Conventions for more information.
| Update | Specification Version Number | Date |
Clarify
start_date and end_date
definitions in the Program Participation File specification.
v1-14-0 | 10/10/2023 |
Update Program Participation
Definition File to streamline the column descriptions and
list the string limit for the program_id
column.
v1-13-0 | 09/07/2022 |
| Update Program Participation Data File Name Conventions to be clearer about file name length limit and what file name components are required. | v1-12-0 | 04/11/2022 |
| Clarify that zip files should only contain one file each. | v1-11-0 | 11/23/2021 |
| Clarify file extension requirements and expectations. | v1-10-0 | 11/12/2019 |
| Edit sections and headings to simplify content. No substantive changes to technical specifications. | v1-9-0 | 01/10/2019 |
| Updated file retention section to reflect regional differences. | v1-8-0 | 05/08/2018 |
| Added statement about valid end-of-line separators. | v1-7-0 | 03/19/2018 |
| Updated description of file transfer process. Added information about correcting file upload errors and Oracle file retention policy. | v1-6-0 | 03/02/2018 |
| Updated the character limit details of the measure field. | v1-5-0 | 06/26/2017 |
| Added a statement about the utility's data obligations. | v1-4-0 | 03/31/2017 |
| Added document number and updated branding. | v1-3-0 | 02/13/2017 |
| Added legal notices. Updated document branding. | v1-2-0 | 01/11/2017 |
| Made stylistic updates to improve clarity and organization. Updated example data. Added a verification checklist. | v1-1-0 | 01/05/2017 |
| Added baseline specification version number to the document. Updated naming conventions to include instructions on how to specify a population token and specification version number in the data file. | v1-0-0 | 10/07/2016 |
