Rate Engine Plus Data Version History
The following table lists updates to the Rate Engine Plus data specification by version number and date. The latest version number should be used in the file name that you send to Oracle Utilities. See Rate Engine Plus Data File Name Conventions for more information.
| Update | Specification Version Number | Date |
| Update Rate Engine Plus Data File Name Conventions to be clearer about file name length limit and what file name components are required. | v1-9-0 | 04/11/2022 |
| Clarify that zip files should only contain one file each. | v1-8-0 | 11/23/2021 |
| Clarify file extension requirements and expectations. | v1-7-0 | 11/12/2019 |
| Remove redundant definition of required files. Update definition and examples of Rate Attributes File file to describe how solar data customers can be identified. Add information about Rate Engine Plus Rate Eligibility. | v1-6-0 | 06/14/2019 |
| Edit sections and headings to simplify content and clarify instructions. | v1-5-0 | 01/10/2019 |
| Added description of new column for rate attribute deletion. | v1-4-0 | 07/02/2018 |
| Updated file retention section to reflect regional differences. | v1-3-0 | 05/08/2018 |
| Added statement about valid end-of-line separators. | v1-2-0 | 03/19/2018 |
| Updated description of file transfer process. Added information about correcting file upload errors and Oracle file retention policy. | v1-1-0 | 03/02/2018 |
| First version. | v1-0-0 | 05/17/2017 |
