Software Version
You can review the Software Version to view the current version of the product you are configuring with the Opower Configuration Tool. This includes a full version history which provides the creation date and summary for each version. If newer versions are available, you can update to a particular version.
To upgrade the software version
  1. From the Opower Configuration Tool select the Settings option, and select Software Version. The Product Versions page is displayed, which lists product version upgrade history.
  2. If a newer product version is available, select the Upgrade to [productVersion] option, where [productVersion] is the new product version to upgrade to. A confirmation message is displayed.
  3. Select Continue to process the version upgrade.
