Global Configs
The Global Configs are a set of required configurations for Digital Self Service - Transactions that define utility information and branding guidelines, web portal configuration, and other configuration requirements to support your Digital Self Service - Transactions web portal.
If the required value for a configuration is unclear, hover over the information icon for the configuration to review applicable information about the configuration, including valid values.You can access global configurations using the steps below:
From the Opower Configuration Tool, select the Settings option, and then select Global Configs. The global configuration options include:
