Field Activity Type - FA Characteristics
Description of Page
Use the Characteristics collection to define characteristics that can be defined for field activity requests of a given type. Use Sequence to control the order in which characteristics are defaulted. Turn on the Required switch if the Characteristic Type must be defined on field activity requests of a given type. Turn on the Default switch to default the Characteristic Type when field activity requests of the given type are created. Enter a Characteristic Value to use as the default for a given Characteristic Type when the Default switch is turned on.
Field activity requests created by the system. When setting the Required switch, remember that most field activities are created by the system. Only turn on the required switch for these types of activities if a default characteristic value can also be indicated
