Configuring Measurement Cycle Schedules
This portal is used to display and maintain a Measurement Cycle Schedule.
Refer to Understanding Measurement Cycle Schedules and Understanding Measurement Cycles for more information.
You can access the portal by selecting Admin, then Device Installation, then Measurement Cycle Schedule. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
- Measurement Cycle Schedule Query: This zone allows you to query for Measurement Cycle Schedules based on Measurement Cycle and select the desired record.
 - Measurement Cycle Schedule: This zone provides information about the selected Measurement Cycle Schedule.
