Configuring Usage Calculation Groups
This portal is used to display and maintain a usage calculation group.
You can access the portal by selectingAdmin, then Usage, then Usage Calculation Group. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
  • Usage Calculation Group: Defines basic information about usage calculation group
  • Usage Calculation Rules List: lists the usage calculation rules belonging to the group
  • Referencing Usage Calculation Rules List: lists the usage calculation rules that reference the group
  • Referencing Usage Subscription Type List: lists the usage subscription types that reference the group
  • Referencing Usage Subscriptions List: lists the usage subscriptions that reference the group
