Maintaining Completion Events
The Completion Event portal is used to maintain completion events.
You can access the portal from the Main > Communication > Completion Event. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
This portal includes the following zones:
  • Completion Event: defines the basic attributes of the Completion Event
  • Completion Event Related Objects: displays data related to the completion event such as a device, service point, or initial measurement.
