Maintaining Consumption Extract Requests
This portal is used to display and maintain a Consumption Extract Requests.
You can access the portal from Menu > Usage > Consumption Extract Requests. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
  • Request: displays the main attributes of a Consumption Extract Request.
  • Request Log: displays all log information related to the Consumption Extract Request.
