Maintaining Notification Suppressions
The Activity portal is used to maintain notification suppressions records.
Refer to About Device Event Notification Suppressions for additional functional information.
You can access the portal from the Main > Communication > Notification Suppression. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
This portal includes the following zones:
- Activity: defines the basic attributes of a notification suppression activity
