Running Oracle Utilities Meter Data Management Reports
This portal is used to submit a new instance of a Report.
You can access the portal from the Main > Tools > Report Submission.
First, the appropriate Report code must be selected. The Reports provided out-of-the-box are:
  • Device Events Report: this report generates a pie graph depicting the percentage of Device Events for each Device Event Type for the specific search criteria.
  • Device VEE Exceptions Report: this report generates a pie graph depicting the percentage of VEE Exception for Exception Type and Market for the specific search criteria.
Next, enter the parameter values for the report as appropriate and submit the report.
